first off, since you only noticed it after you installed the 3" springs, check all of your work associated with the install. did you take the track bar bolt loose when you put the new springs in? i definitely agree that the caster/toe most likely has something to do with it, but i'd definitely check the basics first. make sure that lower track bar bolt is 100% tight if you took it out to put the springs in...
