zith
- Green Mountain Falls, CO
I picked up some tube inserts quite a while back with the intention of building longarms. I'm finally getting around to doing it and found out the tube inserts I bought are made from chromoly. I don't have any experience with chromoly other than what I've read online, so this raises a few questions. Since it's suspension and my safety is dependent on this weld I'm not about to cut corners. I own and have been doing a lot of work with an AC arc welder.
1) Is there any way to weld the chromoly insert to mild steel DOM tube safely?
2) Is there any way to weld these on with the arc welder I've got?
I may be able to con someone with a TIG into helping me if that's the 'right' way to do this. Otherwise, I may buy the right inserts so I can throw them on with the arc and get rid of these chromoly ones.
Thanks!
Thanks!
