DeftwillP
- Round Rock TX
First I was going to do a check on the brakes and flush the fluid. I was planning on Valvoline Synpower(syn. everything else cept the aw4). How about do I go evacuating the current brake fluid from the system, and how much new fluid will I need?
Also, I was going to see if I can pick up some amsoil 75w-90 locally. But I forgot how many quarts I put in the 8.25 last time. I used a gasket last time as well, but I'm under the impression now that I could just use some rtv on clean surfaces?
I was also considering switching from M1 to amsoil this oil change. I typically use 10w-30. Whats the difference with all of the different amsoil products(reg syn, series 2000)?
I also forgot about power steering. I wanted to flush that system as well with some good synthetic. How to flush, how much fluid?
