waggy 44's
Project00XJ
Scotia NY
1986.The front is stock, disassembled with parts painted, and tube stripped. Gears and carrier are not remover. Rear is ready for install. 4.88 gears, aussie locker, HD bearing retainers, complete bearing and seal kit, brakes and all components are brand new. Whole axle is primed and painted black, Tube is bare. Asking $800 for all.
For anyone considering these axles, I run waggy's with 4.88's on 35" tires and I have had great luck with them! I have only blown the short side front shaft once. Other than that they have held up to a lot of abuse. IMO best set of axles you can get and not have to bother with shortening tubes and shafts, ect. Chromo's are available for these off the shelf and can be bought for decent prices, no dealing with custom shafts.
Good luck with the sale!
I will sell the front seperatly, however it is missing a lot of stuff, so im not sure what its worth. The guy I bought it from seemingly took it apart with a hammer. I have the housing, knuckles, spindles, caliper mounts, and shafts. The carrier and gears are all still in place. I shaved the housing, and so you know it is close, the cover will need to be ground also. $150. The tubes are all stripped of factory hardware, and loose parts have been needle scaled and painted.
Thanks for the good notes guys, these really are great axles. I came across a 9" rear and hp 44 front. This is the only reason I am not using these guys.
