gator_grabber
- Gainesville, FL
Our 98 showed a "check engine light" code that indicated the problem was the vehicle speed sensor. I replaced the VSS, disconnected the battery and turned the key to 'start' for 30 seconds, reconnected the battery and drove off. Sure enough, the engine light came back on. The speedo and tranny seem to be working fine (no different than before), so I'm at a loss. Any ideas??
Thanks!
Thanks!
