reiner00XJ
2000 XJ Sport, 1”up country, - rear swaybar. D 35, with Trac-lok. ABS. Stock tires.
Afterm. installs: JKS adjust trackbar. Steering brace. Borgeson steering shaft.
Original setup had slight drive train vibrations from 69 to 74 mph. Almost none after trackbar installation.
Had 2.5“ OME, medium lift installed. OME shocks and steering stabilizer. At the same time new
front and rear driveshaft from Tom Wood and the HD NP 231 SYE from JB conversions. Aligned.
Result: Minor rumbling drive train vibration from 20 to 35 mph. Smooth, noisy from 37 to 68 mph Very noisy, stronger vibrations from 69 to 75 mph. Took HD TC out. (Overkill and too noisy for my purposes, source of vibes?) Had Advance Adapter SYE installed in original NV 231. Assembled. Result: Minor
rumbling drivetrain vibration from 20 to 35 mph. Smooth, quiet to 68 mph. Noise and vibrations from
69 all the way to 80 mph. (Didn’t go further.) Almost as bad as with the HD TC.
Has anyone had similar problems and found a solution? Or, would anyone know what could be at fault?. What corrections to make?
Sorry so long. Any help is greatly appreciated,
reiner00XJ
member 264
reiner00XJ
