mikerhyne
NAXJA Member # 1375
- Aurora, CO
Okay first here is the important details on my rig:
1998 with AW4 that I have owned for just over 2 years and I have done/had done everything listed
-NP231 rebuilt with Teraflex SYE kit
-New stock style motor and tranny mounts, no TC drop
-4.56 gears D30HP & 8.25 open for the axles gears done about 2 years or 6000ish miles ago with new bearings
-Front axle: New unit bearings (Timken), new spicer u joints, new ball joints, power stop slotted rotors and pads (getting a high speed noise from them recently but not too worried about that)
-Rear axle: No idea on age of wheel bearings, just replaced drums, pads and all brake hardware (chasing pulsing rear brakes too but not too worried about)
-Lift: RE 3.5" with full arms, new springs, double sheer track bar and brace, steering box brace (Durango box), and disconnects.
-Cooper ST Maxx tires balanced multiple times
Okay so my issue (the one I'm most worried about) is vibration at high speeds which is noticable/annoying at 65+. Right now I'm not running a front shaft but I get more vibration when it is in that pulsates too. With just a rear shaft in it is more like a groan under power that goes away off power.
My issues started around when I had the gears done but at the same time I swapped out the rear springs (was lifted with blocks, add a leaf and shackles), did the SYE and tcase rebuild, had the front shaft rebuilt and got a new rear shaft locally (rear shaft was crap and ended up as scrap after it was "fixed" but that is another rant). I say around since it is only at higher speeds that you can hear/feel it and when I did all of this work it had very noisy MTRs on it so it was hard to hear at highway speeds. I really started hearing and feeling this when I pulled off the MTRs and put on new tires since they are much much quieter and smoother.
Here is what I have tried:
Taking back to the gear guy and he says everything is good with what he did.
Swapping around axle shafts fronts to rear. I have front and rear Woods shafts and a rebuilt/balanced stock front one. I have run the front shafts in the rear and no change in my vibrations. I have even rotated the yoke around trying to see if I could impact the balance of the shaft and that didn't change anything.
I have shimmed the rear axle all the way both up and down to the point where I get very clear vibrations from the angles. Right now it's about 1 degree different with the pinion lower.
What should I try next? I have some ideas but want yours first
