prljeep
- Toledo, OH
1. Thought I had a vacuum leak- but- now air will go through each position (max, norm, bi-level, vent, heat, defrost) and comes out of the correct holes but only when I am moving above 25 mph or so. The faster I go the more the air moves. AND it can be controled to hot or cool.
What's wrong- blower motor? Can I test it with an ohm meter? Could it be a wire short in the dash?
2. I want to wire the fan on the radiator that kicks on when the AC is on to a switch on my dash. Can I just wire it through my fuse box? There is a white and a black wire coming directly off my fan. Can I assume the white is positive and black negative? With my AC not working, I don't know how to kick the fan on to test pos. and neg.
prl
prl
