mjma
- Rehoboth, MA
I've lifted many jeeps and other coil sprung vehicles and never messed with those dangerous spring compressors!! 80% of them were using jackstands and a jack.
Once you know how to do it, it's easy. Disconnect the LCA, just one bolt, at the axle. Then disconnect the shocks. Now, jack the body up on one side, and the axle will droop enough to drop the spring out. Pull the spring out, throw the spacer up there, then throw the spring back in.
If you were putting big springs in there you might have to disconnect the steering too...but for a spacer, the shock and LCA should do the trick.
The LCA bolt should slide right back in no problem. Just use the jack to get the axle back in it's regular position and then use a rachet strap on either something infront of you or the rear axle to position the front axle just right so that you can slide that bolt right in. It helps to have a friend....they don't even have to know anything about working on jeeps, just to be able to hand you tools and be a second set of hands.
