u-joint question
RNMedic
NAXJA Member #659
Dayton, Ohio
hey all, was perusing the technical stuff, Nothing else to do at work tonight, and one of the articles stated that all XJ's with ABS have the larger 297 u-joints. Is this correct cause I installed an 89 front non -dsico axle and would love to know that I already have the larger U-Joints. John
The 5-260x joint caps are 1 1/16" dia and the 5-297x or 5-760x are 1 3/16" dia (approx...taped, not calipered)
HTH
Just because it was non-disco doesn't mean it has the larger joints, mine didn't. If it has abs, then you got it covered.
kool the wagoneer I stole that and the body panels from had ABS, so that is good to go, Thanks, John. Hey Sean how are ya feeling? pain better? John
