Two truck loads full of parts
You suck.
Seriously.
Dont fret buckaroo, just performing some minor surgery. I got to sell all this shit to get the AC working again. Baby on the way.
And atlas, axles, ORI's, yada, yada, yada :thumbdn:
If you don't give me those CTMs I will tear the doors off your Jeep.
Again.
Good talking to you Phil...been a long while. I may be able to part with a pair of joints. You have some regular old spicer joints??? Need a good set for the spare 44 shafts. If so then you may be able to get a set of Yukon superjoints.
ACOS PROs and Antirock are sold.
Dave gets the 30 spline stuff.
I can not believe that nobody has jumped on full set of chromlly shafts for $250. You guys are retarded. Does nobody need a good set of shafts and extra unit bearings.
Wait...Phil, you want the Nitto 300ms out of this set of shafts?
Here are some pictures of this stuff for those who wanted, or are buyers pending pictures. Still need to pull the Durango steering box and 4:1.
8.25 shafts look good, no spline twist
The spare 8.28 Yukon shaft, also has no twists (I thought there were)
8.25 R&P look good, so does the carrier
8.25 Powertrax looks good. Springs in bag
8.25 Ruffstuff Diff Cover
ZJ Disc brake setup for 8.25
Front Alloy shafts look good, minor wear in the contact area of the inner shaft splines but still look good. Wheel bearings are damn near brand new.
Dana 30 R&P look good, so does the carrier
Dana 30 Ruffstuff Diff Cover
RE Drop Brackets
Upper Control Arms (As previously stated…needs bushings)
Lower Control Arms (As previously stated…needs bushings)
RE HD Trackbar (needs rubber bushing, have extra Johny Joint to go with it)
Currie Steering with extra TREs
AJ, super square rails
Farmboy designs roof halo (Thing is titties, no worries about trees anymore)
Chevy flattop knuckles
Bilstein 5125s
Durango Steering box
JKS Upper shock mounts
JKS Lower shock mounts (need to get a new set of punches to get this off the 7100s)
Im interested in the durango steering box. PM sent
I'll take it all. For free. Pickup tomorrow. I'll even take it apart for a fee!
If I hadnt already taken it apart, we might have a deal. Most of this stuff is gone...But you can have the keys whenever you want it...Tubework and front hoops in 3 weekends....mkkkaayy
This stuff will ship tomorrow...Thanks guys:
Currie Steering
Currie Swaybar and ACOS
Durango Steering Box
Chevy Flat Top Knuckles
Dana 30 High Pinion 4.56 gears (Spicer) with Carrier,
Chryco 8.25, 4.56 gears and carrier,
Chryco 8.25 Powertrax Locker
Drop Brackets
Lower Control Arms
2 Alloy USA 29 Spline 8.25 Shafts,
Dana 30, Alloy USA Inners,
27 Spline Alloy USA Outers, 27 Spline Unit Bearings,
1 Yukon 29 Spline 8.25 Shaft
Sliders
Here is what is left
1 Farmboy Design Roof Halo (1st made, original prototype) $300
1 set JKS Upper front shock mounts $20
Rusty's Cross Member $25
PSC Extreme Steering Box, with Hydro Assist Ports (10+/-Runs) for 03-06 TJ/LJs Excellent Condition $400
RE HD Trackbar $75
Clayton Dana 30/44 axle brackets, 3 link, with highsteer (Brand New) $300
I completely forgot to mention that 10% of the proceeds from all of this stuff sold to Naxja members will either go directly to the Sierra Chapter fund or for the 2013 Naxja jeep giveaway. Maybe split between the two causes. So those of you that bought some of this, thanks.
you lazy sumbitch. I can dig up some old 260 joints...Will that work for you:dunce:
For real though, if you dont want them say so I'll buy them back from you for like $5 or something.
Hey Ben, it turns out those u-joints are greaseable. Do you have any u-joints that I would not have to maintain?
