true tire sizes
thompson97
harrisonburg, va
Anyone have info or a link to get actual tire sizes for multiple manufacturers. I've seen one before, but can't find it anywhere. I want to find a tire in the 32.5" range. thanks
try it this way!
www.tirerack.com/
I give up!!!
Anyway with the possible exception of Interco,most manufacturers tires will be very close in size.I have the chart if you want some numbers!
Actually, MOST floatation tires (the sizes with the inch designations as opposed to p-metrics) run about half an inch smaller than the nominal size. For example, a 32x11.50 will probably fall between 31.4 and 31.6 inches in diameter.
Here are some links for ya:
www.coopertire.com
www.bfgoodrichtires.com
