SteveJ7
- Uniontown OH
I am having an issue with replacing the rear brake drums and pads on my '98 XJ w/ an 8.25" rear. I used a hardware kit with the new pads. The drums I got are 9" and the pads are 9"x2.5", so I believe I have the correct parts for the job.
The trouble I am having is getting the new drum to fit over the pads. It’s a very very tight fit, with basically no clearance at all between the pads and drum. I tried adjusting the pads, moving the adjuster all the way in and the pads still rub the drum. I messed around adjusting the pads in and out with no luck getting the drum on. I didn’t want to force the drum on, but that seems like it’s the only way it will fit. Does anyone have any suggestions for what to do here? Could the new drums be out of the round, causing it to not want to go on over the new pads?? I couldn’t test fit the old drum either because of the lip of rust around the edge of the inner surface of the drum.
This is really frustrating.
Thanks for your help here!
Steve
Steve
