- Roanoke VA
Where is the best place to have a CO2 tank refilled?
Any fire extinguisher supply store or fire prevention store. Usually costs $20. They can re-cert your tank every 5 years as well(required by law) for $20 also.
I'll just add that I do have one of the best Viair compressors, and it does take way to long to fill tires, even with a 5 gallon air tank. I use air for a locker(used to be lockers), and an air horn. Next time I'll have electic lockers, and a CO2 tank.![]()
25 (i think) C02 tank here... its pretty big. love it.
Is it ok to mix co2 with regular compressed air I already have in my tires? Anyone have any links to a decent priced regulator?
I mounted mine in the same place but higher. I no longer run this tool box. I took the back seat out and made tool/spares storage there instead.
What make is that tool box I really like your setup!
I get the 10 lb CO2 tank filled at a local home-brew soft drink/draft beer supply store. About $12 and ten minutes to refill the tank.
I get about 8 refills, raising the 33's from 10 psi to 30 psi.
I use an old SCOTT SCBA tank with a OXY/ACT regulator on top.
The steel tanks hold ~2500psi while the carbon tanks hold ~4500psi.
I did this because I had access to a bunch of tanks and can fill them for free at the FDPT.
I can regulate it up to 200 psi. I can fill up my 35" tires from 8psi to 30psi maybe 6 times. Run air tools if I need to.
CO2 seems to last way longer but since mine is free it was the way to go.
