Track Bars
hards91xj
NAXJA Member #790
Tacoma Wa.
Now that my Rusty`s is ready to come apart again. What options are others using for a 3.5 to 4 in lift.
stock with relo bracket or after market bar?
From about 2.5" through 6.5" I've been using an RE 1600 with the heim joint and the RE 1665 bracket. I've been really happy with it. It's solid, simple and easy to get parts for if needed. It's a heim at one end and a simple poly bushing at the axle end. Fairly hard to screw that up.
x3 on RE
But if you don't want to dink around with any brackets, Teraflex makes a cool one that has a sleeve like the draglink which makes adjusting a hell of a lot easier by yourself. It just bolts in to the stock location and is bigger all around.
