rustys adjustable track bar question
markg
nj
i did a rough country 3 in lift on my 2001 xj.i have 31s on it .all new.
ive just now got the dreaded death wobble.
i see its in the trackbar end at the axle.
its very loose and i cant tighten it anymore.
i see clayton sells a deth wobble fix kit.
it comes with a larger 9/16 bolt and nut plate.
you need to open the 10 mm hole.
they have a stock style bushing that goes in the stock track bar on the axle side.
do any of you know if the rustys track bar will accept the stock style bushing?
Is it confirmed that it is a worn out bushing and not a wollowed out hole. another way to fix is possibly a weld washer if it is the wallowed out hole and bolt moving in the bracket.
