D Down under NAXJA Forum User Location Australia Sep 10, 2019 #1 Dose anyone know the minimum and maximum specs for the lsd plates thicknesses? Thanx
4 4x4JeePmaNthINg NAXJA Forum User Location Colorado Sep 12, 2019 #2 I know stiffer clutch packs are made, this may be fair to assume as the higher end tolerance, maybe.
D Down under NAXJA Forum User Location Australia Sep 12, 2019 #3 Cheers, I can't find any specs anywhere!
R rmoorex NAXJA Forum User Location Indiana Sep 15, 2019 #4 Maybe you have this already? Mopar Part# J099 4345 DISC KIT, Differential Quadratec Part #: 52411.00 Crown Automotive Part #: J0994345 Dana Spicer Dana 44 Trac-Lok Clutches - D/S708203 Hope you can get the info from there.
D Down under NAXJA Forum User Location Australia Sep 20, 2019 #5 Cheers. Going to try and find an 8.25 open cente 're out here and just put the Aussie locker in. Not to fussed on the lsd design. Bit out dated and unreliable.
S Soapy1 NAXJA Forum User Location Idaho Sep 21, 2019 #6 I like my Spartan lockers. If you shop around should be able to get them under $250.
D Down under NAXJA Forum User Location Australia Sep 21, 2019 #7 Thanx soapy, about $425 here in oz, similar p rice to the Aussie locker. Unsure of the better choice.
