Is it possible to convert Crysler 8.25 differential with LSD to an open differential?
hrufino
Hi there. I bought a torq locker for chrysler 8.25 and it works only in an open diff. My is LSD. Is it possible to convert replacing only the carrier? All other gears and size are compatible?
Thanks...
ring and pinion are the same. Should be able to swap in an open carrier or find someone wanting to trade axles.
If you swap in an open carrier, you will need to be able to measure the backlash and basically do a gear setup to make sure you dont wear them out prematurely.
