I have 5.5'' RE lift and a moab4x4 front bumper and would like to tow the jeep behind a motor home. My questions are: 1.) how do you safely attach a tow bar to an aftermarket bummer? 2.) Is there away to lessen the angle of the tow bar to the hitch of the motor home?
You could build one to attach to your D-ring mounts I imagine. MY biggest concern would be the tow bar pointing at a downward angle towards the motorhome. If you were to get on the brakes hard I would think it would do bad things. I think a tow dolly would be a better setup on a lifted rig.
You cant go with the D-ring tab because they are horizontal.You might look at fabbing your own(if you have a welder) or just go with a stand alone set-up.And yes,regardless of the set-up you will need to get the proper rise/drop on the tow bar.
Thanks for the link.... that would work great. My next concern is really the angle of the tow bar to the hitch. A longer tow bar will help will it be enough? I know they make ball hitches that drop down do they make any they rise up?
Edited.... i found these things called hi-rise ball hitches that have longer necks on them...
