To-do List
NEW LIST
-Build jeep
Well I got hydro assist, so that's nice. Maybe ill get the ram in this weekend if its nice out. Other than that, rear bumper and shackle relocators are still on the list, front tube work too.
More of the same. Pick up a new spindle and install new bearings, grease up the other side. Install uhmw in front prothanes, front tube stuff, winch... Whatever I can
Oh boy. Call me I'll lend a helping hand.
Thanks bud but I've assembled a crack team of mechanics, actually its one guy and he's an electrician but I can't see in anyway how this could fail.
install new front passenger side shaft, wheel joints, pick up spare shafts, install H.D. Tie rod, replace control arm bushings, fix C.B., grease bearings on trailer, check fluid levels on jeep and tow rig.
ugh, maybe if I make a list I'll start working on my jeep
-New hydro assist lines - DONE
-Fix dash/wiring issues so the cluster works
-Finish rear tube/tail gate/spare tire mount - DONE
-Tie in front tube work to engine cage and finish inner fenders - DONE
-Dismount at least one rim/tire to fix rim and check a couple of the inner air lock tubes - DONE
-New winch cable/rope
-Add some lights to the front - DONE
-Wire up the AW4 shifter and TCU stuff
-Retighten control arm joints - DONE
-Front limit straps - DONE
-Redo the StaK shifters for a more positive feel
-Change fluids - DONE
-Swap pans on the AW4 - DONE
New stuff
-Buy one new 7100 for the front - DONE
-Rewire trailer brakes/lights - New jack and spare tire mount done, working on wiring now
-Tune the Dodge a little more to find the sweet spot for towing - DONE
-New brakes and stuff on the Dodge
Finish X member Done
build 3 link Done
set up/ build hydro In Progress
Build Mini Tierods
Plumb
Install cooler
finish 2x6 rockers Done enough
would be nice:
build front bumper Nope
re-wire winch Nope
re do all my hard brake lines cause I suck at flaring lines. Nope
traction bar Nope
install 14b pinion guard Nope
- Short test run to confirm new injectors are leak-free
- wire winch
- replace tailpipe with a non-crimped one
Shortened my list
Replace door hinge
Install front chromos
oil change
wire up hand throttle
My list (better not jinx myself):
- Add fuel
- Strap to trailer
- Drive down
NEW LIST
-Build jeep
well that idea went to hell quick, was supposed to buy my new xj 2 weeks ago only to get it last Friday so no black jeep for nac fest but green xj is ready to ride out.
see you all there !
so the xj is out as previously stated, zj on the far right is in, wife is going to be at the wheel so we are wheeling blue/green on 33's!
build 3 link Done
- Build Mini Tierods Done
- Plumb 80% Done
- Install cooler
- Install orbital 90% done
Install Front Driveshaft
weld on shock tabs
Install Tires and trim trim trim
Its coming so close
