To-do List
I never called them, I doubt they will. I might be an a-hole, but Im not that much of an a-hole, I know it was my own fault and need limit straps.
you should still try. worst that can happen is they say no, and call you an A-hole for trying to pull this unjustified warranty scam BS. and put a hex on your future children.
you know no big deal.
the hard way
relocate battery just need some welding cable
buy 42's bought
aquire trailer got one lined up
get tow rig on the road haha
maybee go full hydro gathering parts for assist
-install cb -done
-cut doors off
-t-case skid -done
-gastank skid
-swap in aw4 thats not 230 thousand miles old
-fluid coolers
-fix front pinion seal -done
-install acura rsx seats -sold them to buy new tires
-plate lca mounts -done
-mount up fresh tires and paint wheels -done
-rear locker ?
-tow hitch -done
also installed a aux fan override switch and fresh ujoints over the weekend
I'll start this up again.
- DONE (just final welding/paint needed)Front tubework
- DONE Finish dash and install gauges
- Wheel a few times to get the tune settled in
- Finish floor behind seats
- Clean up hood
- Brace front bumpstop towers/inner fender area
- Build door bars
- Tidy up all the wiring
It's nice having a short/small task list compared to the previous two years :D
Mine:
-Finish front bumper DONE
-Install front locker/chromo's/RuffStuff Cover DONE
-Set-up a coolant overflow bottle
-Fix exhaust
-Fix PS line
-Fix sway bar mounts
-Build back bumper DONE
-New back door/seatbelts/fix PS fender damage DONE-ish
-Half doors?
-Wheel it, break it, cry about how I hate it, then fix it anyway DONE
Updated.
Mine:
-Fix exhaust
-Fix PS line DONE
-Fix sway bar mounts DONE
-R+R PS axle seal/install new PS chromo
-Half doors?
Updated, getting closer...
I also flushed the ATF out of the PS system to see if it quieted it down, and it helped some, but I think I may have gotten a junk reman pump, so I might warranty that before NACfest.
- DONE Front tubework
- Clean up hood
- DONE (built all new mounts...probably add more bracing in the near future) Brace front bumpstop towers/inner fender area
- Build door bars
1. buy tires
2. rebuild all of the superflex joints Bought
3. maybe finish the rear shock hoops
4. maybe securely mount the exhaust5. Install chromos up front Bought
6. Brakes
7. oil and diff fluid
I'm getting lazy... gotta pick up the pace
-install cb -DONE
-cut doors off
-t-case skid -DONE
-gastank skid
-fluid coolers
-fix front pinion seal -DONE
-plate lca mounts -DONE
-mount up fresh tires and paint wheels -DONE
-rear locker ?
-tow hitch -DONE
After a good shake down run at rausch this past weekend I got alittle to add but nothing broke!. not bad for a xj that rolled 230k on the way up there
-ruffstuff diff covers
-sye
-weld in 2x6 box steel for rockers or continue to bash them
-upgrade steering and build steering box brace
-gas tank skid
- build a hd crossmember
- put a freaking bumper on the damn thing
-shave the 8.25, holy shit I forgot how much that damn lip gets hung up on stuff
at the minimum, i can do absolutely nothing and still go
at the maximum I have a boatload of shit to do.
lq9 swap
swap out my entire drivetrain for the doubler
belly pan
driveshafts
bumpers
paint my bare metal thats errywhere
rocker armor
cage
recaros
insulate my interior better
red rope licorice dispenser
yup, maybe half of that is happening. Here is the bare minimum of what I need right now:
recaro's and insulation are pretty much done, also have some nice new fitted carpet on the way
lq9 swap is almost done.
-plug in wiring harness and mount ecm
-weld some exhaust tubing in
-cooling system
-finish my fuel return line.
-wire up my fuel pump
-mount vehicle speed sensor
-do something for gauges (probably get one of them obd2 to mini usb cords and run an android gauge app)
-change the oil and filter.
The cooling system is the big deal breaker for me. I'm gonna need to buy a radiator, fans, hoses, wire them up, and still be able to afford to go to PA and back. and that is if There are no other issues.
Not to mention I have no idea what radiator and fan setup to even run as of right now.
1. buy tires installing thursday
2. maybe finish the rear shock hoops no money for shocks
3. maybe securely mount the exhaust need a new rear mount
4. Install chromos up front Bought
5. Brakes all done
6. oil soon
updated
Mine:
-Fix exhaust -Not happening...
-Fix PS line DONE
-R+R PS axle seal/install new PS chromo - DONE
-New rear soft lines to the calipers
-Install handthrottle
-Grease/tighten/check everything
-Pick up T-pains trailer
just installed max power, so if anyone needs to microwave some noodles or do some curls in their hair hit me up....
2nd durango steering box for 2013, good to go
oba all tuned up
