1.) WELD exhaust, or try a pepsi can, i've heard they're stronger that coca~cola?
2.) RMS/Oil Pan
3.) Tail-Lamp Re-Wiring (help!)
^ I used trailer wiring harnesses to make my oval tail lamps function as dual element running/stop lights.
Maybe I bought cheap harnesses, because:
* one side only comes on with the brakes, not with the running lights
* the other side only works as a running light, and doesn't get brighter with the brakes
-Replace front hubs
-Bleed the brakes
-Change front diff. fluid
-Fill t-case fluid
-Flush the coolant system and replace the block temperature sensor
-Weld a new trackbar bracket on the axle
-Weld new control arm mounts on the axle
-Tube fender flares
-Make/weld some stand off bars on my rocker replacements
Not sure what I'll end up getting done...but that's what I'd like to get done.
-install rear limiting straps
-build rear tube fenders (so I don't get a ticket)
-build front tube doors (maybe)
-buy new trailer
-replace front bent leaf spring
My list
1.make shackle reloction brackets
2. possibly a rear tube bumper made??
3. BECOME A MEMBER cuz i kinda need to be if i'm gonna be going
4. Maybe put a couple roll bars on the inside
I'm way behind. Still gotta put the full spring pack in the rear. Get hockey pucks for the front in. And install the durango box. And get an alignment.
Well guys I'm all ready to go. I replaced all my axle u-joints (including spares) with 5-760 joints, checked all fasteners, and lubed everything. Two spare alternators were purchased for Kaner. Re-tuned my CB. I installed a towed vehicle braking system in the jeep and also fabricated some tow bar brackets to adapt a blue-ox towbar to my tow-points. All that's left is to buy food, drink, pack clothes and firewood. A spare starter and steering box from PIP might be in order since my box is clunking a little. LESS THAN ONE WEEK LEFT:yelclap:
My list
I Became a Member so that's a big check mark off the list haha but sadly i wont be able to do all this stuff up above with so little time left but its not abig deal. i atleast got some lights put on it so thats always good i guess
well since time and money has been absent the last couple of months, my list has changed a little:
-replace rockers
-OBA
-SYE w/new DL, if I have time...
well the only thing i got done was the rocker replacements. not gonna have time to do the other stuff on my list. hopefully this summer i can do those things....
between now and friday, just gonna check/change fluids, check all my torques. gotta pick up some spare parts and UPS just dropped off a set of Solid brand diff covers, which i will install when i do the fluids.
Trac bar ...... done
Spring pack......done
Hockey pucks...... done
Alignment....... done
Durango box...... going in tomorrow.
A few minor odds and ends but for the most part I'm done and ready to play.
swap out 4 lower control arms -Done
Check all suspension bolts -Done
replace Pass side knuckle and Caliper bolts -Done
Make Flaps -Done
Still to do
Swap steering out
Top all fluids
Load jeeps
Load trailer
