yeah mine sorta was up in September... gotta get that handled :eyes:
I've got a long list It'll be done though!
To Do:
Drop in motor DONE
Bolt up Trans and Tcase DONE
Make high clearence Xmemeber Might not do
Build 3 link DONE
Dig rear 60 out of snow BOUGHT D60-ISU and installed
Regear and re bearing front and rear 60s- Might not get done
SYE
Driveshafts
Cage
front DONE and rear stiffiners
Track bar
Brakes
Tank Tuck Halfway done
Looks Like ive got some work cutout for me...
is your a dd as well?
lower front
install rcv's
buy steering ram and install
weld on beadlocks
set caster
fix floor
put on new winch rope
run shoot the moon to see if i can make it up with out breaking :thumbup::thumbup::thumbup:
Working 7 days a week really puts a hamper on jeep work.Got another Jeep so this list is scrapped. New List
Fix front driver brake line DONE- New Hardline installed
Put interior back together
Install rear seat
Install rear shocks
Buy and install front shocks
Install TJ rear flares on front- Bought
Fix small rust hole on roof
Take apart suspension and paint.
Fix passenger window
Frame stiffeners
Get new rear leafs.
New unit bearings.
Rear disc brakes-Done.
2x6 box rockers.
Think that's about it. All of it but the unit bearings I can go without but I want to do it. Just gotta hope it dont break down right before.
Sounds like you bought the white one off of arb
Yup wound up getting that. It's a lot easier working on it when I have another Jeep to drive.
1. Get box 4 rox doubler started and done...DONE
a. install shifters
2. Fix track bar/hydro mount... DONE DONE DONE
3. Go Wheeling
STROKER
- Build front truss for steering ram - DONE
- Finish front suspension mounts (shock, coil, box in link mounts) - DONE - shock mounts
- Build track bar and brackets - DONE
- Build control arms - UCA DONE
- Put rear suspension together (weld in perches, shackle hangers)
- Build rear bumper - DONE
- Finish bobbing the bed - DONE (just needs paint)
- Build rear wheel wells - DONE
- Gear, assemble, paint both axles
- Prep new leaf spring packs - DONE
- Figure out brake system (hydroboost) and associated plumbing
- Modify fuel cell to accept YJ sending unit
- Build fuel cell mount
- Relocated battery to bed
- Build rockers - DONE
- Put interior back together and run the wiring harness
- Modify bracket for slave cylinder
- Exhaust (hopefully stock downpipe, muffler, and then turndown at rear bumper)
- Cage if time permits
- OBA setup
- Driveshafts front and rear
Added some stuff to it.
to do list: one tons for J10
I keep breaking random small stupid junk and not fixing it till right before the next run or right before it explodes and ruins my day.my to do-list changes every week because i actually wheel.
so im not gonna bother updating it anymore
