Darky
- 29 Palms, CA
Rock Krawler sells their 3 link upgrade for $700 thru Desertfab.com. Then you can piece together your springs from whatever you want. If you're only doing 3.5" you can get away with a t case drop, most likely. The newer XJs can tend to be more picky. Even if you do need an SYE, you can get a hack and tap and double cardan drive shaft from DPG for under $400.
