TMC-XJ
- one stoplight town, Idaho
I had time to finally install the RC Shackle Relocation brackets I got from a CF member. Thanks again Chad!
Now if youve been following my thread, youll remember that I mentioned my shackle boxes only have one hole facing the front, when the RC brackets need two.
Here is a shot of my driver side for reference:
A fellow
member (RedJeep2.0) had the same problem only his was a Renix-era 88.
Any options......? Drill it out!
I started with the passenger side. You reuse the factory shackle bolt plus the supplied two front bolts.
Here it is with the top bracket bolted in:
Then you bolt up the bottom bracket to the top, as well as set the shackle with the supplied bolt. I think RC recommends trying the middle hole.
Here is another angle. (I know, I gotta change/adjust the exhaust)
Now on to the driver side. You have to remove the gas tank line "skid plate" cover. Get ready for a POUND of dirt to fall when it comes out. Haha!
Unfortunately the gas tank filler hose/vent tube are right in the way of drilling the upper hole.
My solution....? Unbolt the filler neck and unhook it from the inside of the body panel, and push it down and out of the way.
Here it is with the driver side drilled and upper bracket bolted in, and I hadn't reinstalled the filler neck at this point.
So after installing the lower bracket and lowering the Jeep back down the shackle was bottomed out on the bracket. So I had to reinstall both sides on the next hole back.
So install took me about 6 hours since it was raining off and on and I had to re-adjust the shackles. Now I did receive a slight lift from the brackets like RC states, but unfortunately I still have a slightly-under vertical shackle angle. Mainly due do to the fact that its the stubby/wide factory shackles, with longer/narrow ones I could put it back on the middle hole and have a much better angle and a better ride.
After install thoughts?
-RC made this a pretty sweet and easy install product, just had a little more time in mine
-Still no driveline vibes (even thought I still need a SYE)
-The back bounces around a little more (obviously cause of the shackle angle)
-I need longer rear shocks/brake line (duh! haha)
NEXT!
Since I dont have rust anywhere I want to avoid getting it anywhere so I removed my factory chrome roof trim on the drip rail. Also the Jeep was missing several whole and pieces of its badges/emblems, so I removed the ones remaining for now. (still deciding what to do about the paint)
Only found small surface rust on the spots where the trim's clips attach. Cleaned and just primed them for now, they're only 1" x 2" spots.
NEXT!
Found a guy selling a bunch of random Jeep stuff and got these stock Jeep Turbine center caps.
Complimentary before/after:
Hot/dry September '14:
Rain soaked April '15
I think its coming together pretty good so far. Especially since its on a budget and isn't being built for stuff it will never see/use.
More to come before the little one arrives.
Thanks for reading!
A fellow
NEXT!
NEXT!
Thanks for reading!
