toyworx
- Middletown, CT
casm said:What I basically want is a solid understanding of what may be involved in doing the swap. That's all.
1) Bolt in the front (links, steering, brakes, etc).
2) Get TomWoods to make the front driveshaft.
3) Torch all the TJ brackets off the rear axle. Buy spring perches ($50.00), set it under the springs with the perches loose and the ubolts just tight enough to hold it all together. Get it centered and the pinion angle correct, tack weld the perches.
4) Weld some lower shock mounts on the rear axle
5)Unbolt rear axle, finish weld perches
6)bolt in rear axle, connect brakes, etc.
7)swap in proportioning valve from Rubi.
8)Get TomWoods to make the rear driveshaft.
9) Rig up a compressor setup from ARB with Dash switches.
10) Wheel it like a rental
If you put your mind to it, and have all the parts in front of you, it's a weekend project with the exception of having the shafts done. Thats a 48 hr wait.
