family XJ
- Jacksonville North Carolina
I'm looking to upgrade since mine is worn out. I was going to buy Rustys. Any thoughts or recommendations on this?
TIA
Doug
TIA
Doug
How much did the ZJ rod set you back?Handlebars said:You could do the V8 ZJ tie rod upgrade while you are at it. Tell the parts guy that you want the inner and outer tie rod ends and adjusting sleeve for a 95 Grand Cherokee with a V8 and you will get something that looks like this:
The tie rod is solid steel as opposed to the hollow tie rod that comes stock on an XJ. Stick with the XJ drag link, the ZJ one doesn't fit.
Incredible Hulk said:I just bought one from goferitoffroad.com and it is beefy as heck! Its huge! And I got some dodege 1/2 ton TREs to go along with it so its pretty beefy! Now my drag link is my "weak" link!
Incredible Hulk said:WOW! I am surprised to hear you were able to bend it! It seems awful stout! How did you do it? Thats crazy! Good to hea ryou would buy it again though!
family XJ said:So does anyone out there run Rustys tierod converion? I also saw someplace that offers a way to run the tie rod on top of the ball joints vice running underneath. Anyone do this
