btt = back to top. he's bumping your thread.
I would suggest welding a long piece of rod to the turndown and hooking it into the rubber hanger over the axle, it will bounce, and it will cause problems. first the weld will snap off of the pipe where it goes into the runner on the trans mount, then the whole thing will start moving around and bust your exhaust manifold to crap. I learned my lesson after the third time :gee:
also bails, with your pipe turned down like that you're going to A) get more exhaust fumes in the cab if you are sitting and idling in traffic, and B) the heat from the exhaust is going to go directly at the rear axle housing and steel brake line for the rear passenger wheel. Once you get it driveable take it for a spin and feel the passenger side axle tube vs the drivers side, you'll see what I mean.
Mine is turned down there too, but I change the oil in the diffs every time I change the engine oil because I know its being affected by the heat.
