clean4drxj
- CT.
I'd also recommend some heat tile on the bottom of the newer style intake, it has alot more surface area(above the header) than that orginal one.
Ask Adam (XJLI) about his OldMan experience on here.
I've been debating doing the same adjustment to my '01 Dodge 2500. My father shares the same sentiments that it isn't a good idea, however I've read of too many success stories.
I've read to do the input bearing preload adjustment first. If that doesn't do anything, then do the over center adjustment in 1/8" turn increments at a time.
I might try it in the spring.
Good read on jeepforum.
I'll have to use that when I go to do the box in the Dodge.
So i decided to try my luck at rebuilding the steering box myself. Ordered up the Edelmann 8675 rebuild kit for the 96+ box. This one comes without bearings, just all the seals, spacers and orings basically. To get bearings you need to order the 95- kit and use the bearings from that, however the sector shaft bearing has a slight variance in it, a lip that locates the bearing correctly. I was able to find this bearing (INA SLH 12501) on ebay. Once i get that i can start on the rebuild if the weather cooperates..
My best bud decided to part his YJ he bought new after finding some frame rot he wasnt comfortable with so he bought an LJ Rubicon. A year back he had a new Borla muffler replaced under warranty, he threw it at me to use behind the Borla header i picked up from GI-John. Guess i'll look into a stainless catalytic converter.
Tonight i scored a good deal on choice parts from a 93 ZJ with manual trans, bought the pedals/ECU/shifter and boot. Anyone got a wrecked but running V8 ZJ lying around?![]()
Great score on the 5 speed parts. Do you have any pictures of the Jeep it came out of? Curious to see if it was a Laredo or a base model.
HOW YOU TAKA THAT PICTURE??? YOU HAVA THREE HANZ?
I have a film crew..
:bs:
But wouldn't from the right end of L5 to the right end of L1 be the usable length?
