think this will fit?!
Same one im running! Did rip out my AC though, but it was not just to make it fit. Bet there is room, and the grille is just plastic so you could always notch a bit out.
austinaubinoe- How did you plumb your tranny cooler? did you still run it through the rad or just to the cooler?
o-guage-steamer- where did you move your tranny cooler then?
I would like to share an observation. I recently moved my Aux trans cooler out from in front of the radiator and I got a solid 5F drop in engine temp.
Do you have that shovel just mounted to the sheetmetal of the fender?? Sorry for the derail....
its all good i have A.D.D. too :) i saw that too and was like WTF thats a pretty cool idea, there's another guy on here that has his mounted to his rear quarter panel.
i used that exact one and it took a while to squeeze it in there. it is barely touching the condenser, but it came with little pads so i put one between the cooler and cendenser. and i had to trim a small piece of my header panel. it was a huge PITA to git situated but i wanted to get it in instead of getting a thinner one. the B&M 70268 is the same height and width but half as thick. and i put mine in front of my mechanical fan so air is always moving across it.
crappy phone pic
awesome thanks for the input guys. oh and 1990 jeepxj how does this thing work? do you have a temp guage?
