Things to do before the Crawl.....
-Tires
-Figure out alignment issues
-Fab up a rear tire carrier DONE
-Front axle u-joints DONE
-Shackle relocation brackets DONE
-New lower control arm bushings DONE
-Get spare big joint small shaft DONE
-New centering pins on rear leaves DONE
-Driver's side wheel bearing and hub
-Grade 8 hardware for tire carrier DONE
-Swap rear leaves side to side DONE
-Get junkyard replacement driver side mirror DONE
-New leaf spring bushings DONE
-Register for the Crawl
Rear Bar tubes: Done!
Repair Fuel Pump Ground: Done!
Taillights/fix headlight switch: Done!
fix rock lights on front
fire extinguishers: Done!
tool storage tie downs: Done!
Mount spare driveshaft's: Done!
New tie rod: (waiting on Ironman Andy to ship) Done! Picking up when I go to DT!
35 spline stubs and flanges:
tune up, fuel filter:
air filter: Done!
plugs:
address noise under hood, suspect e fan It went away..... Done!
maybe move power steering cooler to the rear cage:
steering column:
Fix breaking leaf spring mounts Done!
Relocate Battery to rear:
On board air:
You're not gonna out bacon us!!!
Locker is ordered for my Ford 8.8 LS diff. Woot woot!!!! I should have it no later than Tuesday.
I need to get my bearings and seals and I will be ready to get the rear end done.
I thought you could only put a locker in an open case.
PowerTrax offers the only 8.8 LS lunchbox locker out there. Part number 92-0688-2128. The locker was too good of a deal to pass up.
I can mark "register" off my list.
Yep, Ed! Me too!
-Tires
-Register for the Crawl DONE
Replace rear leaf springs
Dana 44 truss
Brown dog motor mounts
Replace cracked windshield
Come up with a different kind of front upper bumpstops
Change fluids
Dove tail the front/ or something of that nature
Redeck trailer
New trailer lights
Updated after my DT trip...
Fix/replace windshield:
New tie rod: (waiting on Ironman Andy to ship) Done! Need to be painted and mounted....
35 spline stubs and flanges: $$$ Says on hold....
air filter: Done!
plugs:
steering column:
On board air:
-Tires
-Driver's side wheel bearing and hub DONE
-Grease all fittings DONE
-Oil Change
-Transfer case fluid change
-Recharge A/C
New tie rod: Done! Needs to be mounted....
air filter: Done!
plugs:
steering column:
On board air:
