Things to do before the Crawl.....
-Tires
-Figure out alignment issues
-Fab up a rear tire carrier DONE
-Front axle u-joints DONE
-Shackle relocation brackets DONE
-New lower control arm bushings DONE
-Get spare big joint small shaft DONE
-New centering pins on rear leaves DONE
-Driver's side wheel bearing and hub
-Grade 8 hardware for tire carrier DONE
-Swap rear leaves side to side DONE
-Get junkyard replacement driver side mirror DONE
-New leaf spring bushings DONE
-Register for the Crawl
Rear Bar tubes: Done!
Repair Fuel Pump Ground: Done!
Taillights/fix headlight switch: Done!
fix rock lights on front
fire extinguishers: Done!
tool storage tie downs: Done!
Mount spare driveshaft's: Done!
New tie rod: (waiting on Ironman Andy to ship) Done! Picking up when I go to DT!
35 spline stubs and flanges:
tune up, fuel filter:
air filter: Done!
plugs:
address noise under hood, suspect e fan It went away..... Done!
maybe move power steering cooler to the rear cage:
steering column:
Fix breaking leaf spring mounts Done!
Relocate Battery to rear:
On board air:
Buy beer and bacon
I think this year I'm gonna try to trump Molly's pitcher 'o' bacon at the potluck...I'm thinking...CANDIED BACON!
You're not gonna out bacon us!!!
Locker is ordered for my Ford 8.8 LS diff. Woot woot!!!! I should have it no later than Tuesday.
I need to get my bearings and seals and I will be ready to get the rear end done.
I thought you could only put a locker in an open case.
PowerTrax offers the only 8.8 LS lunchbox locker out there. Part number 92-0688-2128. The locker was too good of a deal to pass up.
LOL :D
I made 3 pounds of it Sunday...it literally lasted 10 minutes amongst 10 people.
I can mark "register" off my list.
Yep, Ed! Me too!
-Tires
-Register for the Crawl DONE
Replace rear leaf springs
Dana 44 truss
Brown dog motor mounts
Replace cracked windshield
Come up with a different kind of front upper bumpstops
Change fluids
Dove tail the front/ or something of that nature
Redeck trailer
New trailer lights
Updated after my DT trip...
Fix/replace windshield:
New tie rod: (waiting on Ironman Andy to ship) Done! Need to be painted and mounted....
35 spline stubs and flanges: $$$ Says on hold....
air filter: Done!
plugs:
steering column:
On board air:
-Tires
-Driver's side wheel bearing and hub DONE
-Grease all fittings DONE
-Oil Change
-Transfer case fluid change
-Recharge A/C
New tie rod: Done! Needs to be mounted....
air filter: Done!
plugs:
steering column:
On board air:
