NorCalChris
- Central Coast, Ca
- swap out dana 30 for a straight one
- rebuild and revalve my Bilstein 7100s
- install adj ucas
- find the configuration that had the longest stock front drive shaft...and get two shafts
- install sye
- relocate the shock mounts on my d44
- install some shackle relocators
- weld in new rockers
- fix my hood latch
- fix my pass rear door , i need a new handle and internal assembly
- maybe make some half doors?
- mount an antenna and run wire to my cb
- mount my power converter somewhere
- run a 12v supply to the rear of my jeep for my cooler
- install some more tie downs in the rear cargo area
- make a new prop for my hatch
- put my dash back together
- clean the inside of my jeep
- service the engine, tranny, fill my case, and f/r diffs
- mount my two spare tires on rims
- find more stuff to fix........
- and last but not least............become a naxja member
