irishexpat
- columbus oh
lucky you......i saw the same tip on cherokeeforum but neither of the walmarts near me had them.....
Hey Rew, you get them all wired up?
this was unexpected but thanks to an insider tip in the important thread i picked up some hella 500's for the front bumper and 500ff's for the roof rack30 bucks total
Just stick some washers in there and it should get the lights a little lower so they will point straight.
You warred something wrong...Thats what i did to get my lightforces to mount. Andrew did you ground the underhood part to the body or the negative on the battery? I can't get the relay to trigger on mine unless i jump it.
I have a nut in there for a spacer right now and still need a little moreJust stick some washers in there and it should get the lights a little lower so they will point straight.
thats were im going tonight!!!!!!Walmart, they had them for 10 bucks a box apparently there getting rid of the brand.
I have ground in the cab, the switch lights up, The trigger wire is going to the middle terminal on the switch and the power wire is on the positive terminal. So somewhere between the battery and the relay is where my problem lies. Hubs, I can go to the Hella site and look at the instructions. I've wired up a couple sets, I shouldn't need them.......guess i was wrong.
still dont see any sliders installed yet...haha
Maybe i have the blue and yellow on the switch backwards...........I already tried switching the green and yellow.Aaron, swap the yellow and green wires. Rew, check yours too.
With the O (off) oriented up, yellow wire(trigger) goes to #1, green (power) #2 , blue (ground for switch light) #3.
