THe NAC Lots-O-BFG KO2 Thread
SO ITS COOL I CAN DO WHEELIES AND YOU CANT
I KNOW HOW TO DRINK COFFEE SO SHUT UP PUT IT IN A CUP AND SIP IT WITH YOUR MOUTH DONT DRINK TO FAST OR YOU'LL BURN YOUR TONGUE I DRANK ONE THIS MORNING I CAN PROVE IT TO YOU SO XXXX YOU COLIN I KNOW HOW TO DRINK COFFEE GO SUCK A DICK
I wish I could go to the 99 tonight and hang out with sheep but I have to take a gay test tonight to prove that i'm gay. I'm studying right now for it. Penis goes in butt, **don't slap it away(that's not gay)** and balls must touch, or not gay.
Still learning.
a suckdown winch at each corner would be cooler.
you could 3 wheel it to change a tire.
im smarter than chris
Too heavy.
Couldn't you also just have a d-ring tab on each side of the axle and use your winch to hold it up?
The chain is fast and simple. If you wanna get out and crawl on the ground at Line Mountain under a muddy dripping truck to try and route a cable from the front to a back corner of the frame and then down to the axle, then spool it all up again, that's your call...meanwhile I've already got my tire in the air and halfway off.
The uppers have flex joints at both ends already. The lower mount isn't 100% parallel from frame to axle so the rubber bushing isn't gonna last
OHH.
I guess I can pull a link off: -/
Imma run it til the bushings splode then do something about it
There ya go.
Wheel the XXXXing thing once before you go changing shit.
I don't know anything about suspension but I'm pretty sure every link set up is the same. Bunch of tubes bolted to the axle. The more the merrier. That's all there is to it.
I have an 8 link, flexes like crazy. Got plans to add a couple more links. It's gonna blow your minds.
I just found out everyone on earth is asian.
Nevermind false alarm, there are some that are not asian.
Correction everyone on earth is in fact asian. Including non-asians.
I modify my previous statement. 1 out of 3 people on earth are asian.
It is true however, that no one understands spanish.
Spanish(the burrito language) was once thought to be jibberish is now understood to exist solely for the naming of bean related food items.
you suck at building jeeps
i have actually seen this on more than one occasion
Chalupa burrito supreme taco bell enchellado. Translated- "Excuse me business man, but do you know the square root of x-3?"
