cmelo
- Stoughton,MA
Why would you take your steering shaft out? I'm pretty sure I can use any jeep shaft that bolted to a saginaw box. I know an xj will be the right length though. What I need it for is my steering shaft has a u joint up top near the column but a rag joint at the steering box. The lower shaft slides out and you can slide the lower half of an xj shaft in to get a u joint instead of the shitty rag joint. It's the final piece to my steering.
carmelo i got one in mine, aint like its goin anywhere soon, i can scource one from a late 80's xj if that be better
