THe NAC Lots-O-BFG KO2 Thread
For the 8.25 haters.......
.!.:D.!.
So I took out the thrust washer on the stub shaft and everything spins mint, but I can't get the dust cap on the hub without the same problem again.
The shafts are the same length and everything as Ross's stockers. I think the knuckles are the problem.
So I went to assemble the rear. I can't get the wheels to seat all the way down because of a ridge on the hubs. I'm going to have to pound out the studs and grind it down if I can't get to it with the studs in.
that sucks balls dood, you sure you took enough off the h2's? your frt issues makes me almost want to toss the shafts into mine but ill wait on that gotta get this motor back in, gonna gram a timing chain and new harmonic balencer tomorow
then why not make the center bore of the wheels bigger?
They fit over the front hubs no problem. It's just the rear. Has a small bump up right before the rotor.
Why don't you call the company you spent 1 million dollars on for the knuckles you think are the problem, shithead. The least they could do is give some advice.
It would mean getting Ross's assistance again which takes forever lol.
That's my plan for tomorrow. Wanted to be sure dumbass. I dont call and whine without reason.
Hand held drill and a sacrificial bit. Blam, done!
My room looks so crappy now that I have everything off the walls and packed up/taken home already.
Travis your rockers done yet?
Nope! It'll all be together by memorial day weekend, other than that i dont really care to hurry too much haha. Ggetting wheels this weekend, once i mount the tires im sure thatll put my ass in gear a bit more. You gonna be cruisin around in the big jeep by then or what??
We interupt this thread for this special announcement:
Hella 500FF's being blown out at Walmarts for $10.
We now return to our regularly scheduled program.
To bad I really have no reason for lights, that could be a good deal.
Thanks for the tip anyway.
ill be lucky to have the drivetrain back in by then, still waiting on the flywheel bolts, im really hoping to have gears/locker/spool ordered by then,im also kinda waiting to get my summer work sced planned out
