vetteboy
- morganville, nj
It *might* clear if you install the motor with the filter already on it, but even then I don't think you'd ever be able to unscrew it far enough. I noticed it when I was dropping the motor in and changed it back to the right-angle adapter I had before.
The side of the right-angle adapter that mates with the motor is effectively an 'oil filter'. The O-ring and all that are the same, and the gigantic torx head thing screws into the threaded hole in the block where you'd normally have the part to screw the filter onto.
really now :read: I'm gonna have to try that on my spare motor next time I get a chance. Does it interfere with the frame rail at all?
