asp
- Westport, MA
i ordered a nice set of 6 fluted countersinks from amazon too...
No video... not this time anyways. Up to anything tonight? Pretty sure we'll be working on it again, or can at least fire it up.i certainly hope someone got that on video!
Yeah, we open the garage door and fire it down the driveway, it's a good thing his next door neighbors already moved out because that thing is LOUD. Right now we're pretty sure the combustion chamber needs some redesign (it's a ghetto hack to test if the idea works at all right now) because the flames make it into the turbo and you can hear a kind of crunching/popping noise as bits of flame go through, when the flames aren't coming out the exhaust it sounds great and runs smooth. Due to the flames coming out the exhaust, when it starts up, the turbine blades glow cherry red and slowly cool down once most of the flames retreat back into the combustion chamber. I want to get an O2 sensor bung and the flange that bolts onto the exhaust port on it and build a closed loop control system for it so we can get optimum mixture and stop burning the hell out of the turbo but the other guys are of the FIRI mindset right now, till they get the combustion chamber and ignition setup working right. It's actually working well enough now (on the first revision no less) that it's self sustaining after about 20 seconds and doesn't require the leaf blower or ignition circuit past that point.a friend of mine has something very similar in his garage...
100000% agreed.I wish I was leaving work right now.
Should have taken the morning off.
If you haven't heard of it yet, check out www.used-tools.com - the rest of the jet engine/hovercraft team spent half of yesterday there (it's in Worcester) buying tools. Apparently they have a massive assortment of random reamers, mills, etc etc etc and if anything lasts more than a week they put it on a huge table in the middle where everything is $3. I need to go there ASAP, only heard about it last night.i ordered a nice set of 6 fluted countersinks from amazon too...
blah blah blah We then decided that we hadn't played beirut in far too long and that is the plan for the night... I told him I was leaving work at noon. He didn't argue. :thumbup:
wow, that's nuts. i'll check it out. i am really happy with my tool purchases of yesterday though. i could use some other stuff though too. like big taps, big drill bits, a drill press, oxy ace torch setup... i don't even have a sawzall. oo... an air compressor would be handy too. :banghead:
You actually call it beirut? Not many people around here do. Usually just call it beer pong.
rob: details on the lug nuts? are they the good ones or the crappy ones that the coating comes off of. i only have crappy ones...
hmm, not a bad idea. they are just for wheelin anyways. maybe i'll grab a set of those. where would i get em? dealer?
I don't think his lugs will work for you... you don't have 9/16" studs do you?rob: details on the lug nuts? are they the good ones or the crappy ones that the coating comes off of. i only have crappy ones...
I got mine at the local parts store, had to order them, but I saved a few bucks over SummitRacing.hmm, not a bad idea. they are just for wheelin anyways. maybe i'll grab a set of those. where would i get em? dealer?
Personally few the few bucks I wouldn't risk junkyard lugnuts.i'm sure junkyards have lugnuts kicking around, might have to ask though.
Incorrect information. Mine came from Advance, ordering 34 of them (2 spares) was way cheaper.don't bother with autozone/advance, it's like $3 for each lug nut there, which is WAY too much if you're buying a lot
Yup, super bling! Mine look like these:chrome plated super blingy ones
http://www.summitracing.com/parts/SUM-7540163/
I refuse. :moon:go post all this crap in the tech thread...
Which is why I've got open ones. I would like Rob's nuts (hehehe) though, his will keep the stud threads clean.They're friggin lugnuts.
Get the cheapest you can find.
Don't need no fancy crap on 'em.
