THe NAC Lots-O-BFG KO2 Thread
ok. i'll talk to nick about it some more.
I have to try and get inspection tomorrow. Only three things concern me.
1. Passenger side caliper rattles.
2. Gas tank leaks.
3. Compression fitting in plain sight.
I figure the rattling very likely wont matter. The gas tank wont smell tomorrow after driving in the snow. Then maybe since everything is all wet they wont check the wheel for play and miss the compression fitting.
:thumbup:
Then I'll clean up my mess in my girlfriend's garage and half ass slap the 2wd beam in the xj and tow it away.
THEN ONTO THE HONCHO
I
2. Gas tank leaks.
I wouldn't worry much about the compression fitting. The green jeep had a few of them in plain sight, and people inspecting it saw it easily. Now, the rear wiper motor on the other hand, damn that's a big deal. If that's not working, you sir are FAWKED.
:D
:woohoo:
They won't notice any of that probably. Make sure you have your front license plate though :lecture:
Good morning. My boss isn't coming into work today so I hit snooze a couple extra times. Good stuff.
Nice. I have an 830am class. Can't skip it because I decided to sleep through it on Monday.
But the ball joints won't!!!
On another note: Did you get that DSS on?
Good call. BJs to come in the spring...uppers haven't gotten any worse and the lowers are still good.
Nah, need to get that socket. Ross says his might work so I might be picking that up tonight, idk, I have a lot of homework due Friday.
i have low pinion 5.38's and a lockrite
i break 3 rules regarding gear longetevity
-super low gears=less ring gear teeth and miniature pinion gear=weaksauce
-low pinion= moar deflection=weak
-floppy stock carrier=floppy weak
the US hockey team's goalie was the goalie at UMass when i a freshman and sophomore. he was wicked good then, too.
Isn't Tim Thomas one of USA's goalies???
his name is jon quick, FWIW
However is that in a D30? Could make a bit of a difference :laugh:
his name is Jon Quick, FWIW
What a name for a goalie. There was a big thing of him having a "Support the Troops" emblem on his mask. They made him take it off. I think there's a thread in off-topic about it.
