XBoBJ
- Spencer MASS
anyone have the rubicon express controll arm joint tool i can borrow?
Thanks again on that link. I think that the only thing that wasn't explained perfectly well in that page was the years/widths for narrow track FSJ D44's. Or maybe I am just being dumb (or wishing the WMS-WMS values were filled in)
I THINK I now know what I need: If I want to shorten a HP44 and run high-steer I would need to pick up a 73-77 F150 axle (or through 79 if it came from a supercab) along with the inners/outers/knuckles/hubs/etc from probably a late 80s grand wagoneer.
I hope that's right. I will read more later :gee:
When I rebuilt my RE joints I just replaced the races. The rest of it was is great shape and with a little nickel polish was good to go.
I don't care what lug pattern I run so it doesn't matter to me. I was actually just thinking about if there is any benefit to a 6 lug vs a 5 lug pattern.right, but if you want to use a 5 on 5.5 bolt pattern you need to also use the ford's hub and rotor![]()
Oh god, now I have to think about spindles? :rof: I was thinking I might be able to (hoping to be able to) just be able to run the shafts, kuckles, spindles, and all from the waggy. son-of-aAnd you need small bearing spindles. 80s wagoneers will have big bearing spindles.
U-joints are easy. The only "difficult" part about the wheel joints is breaking the hub free... it can be a PITA. If you are ever down this way for everett's again or something you can swing by and change them in the heated garage. Makes life a bit more bearable.
Speaking of junkyards, has anyone been to "self served used auto parts" down in E. Freetown (or Assonet)? I heard they have a pretty good selection and all the vehicles are kept lifted off the ground a bit. I think I might be checking it out this weekend.
Glad they have!theve held up to a year of severe abuse by me and are still great
so to keep the 5 on 5.5, all i have to do is narrow the long side and use a waggy inner. then the rest will stay the same unless i change to flat top knuckles, then i will have to get a different spindle?
sweet deal for someone looking for a trailer to tow there rig
http://nh.craigslist.org/pts/1546225473.html
For 5x5.5 AND flat top knuckles...
- Your choice of flat tops (except F250s)
- Small bearing spindle (early chevys or FSJs have these)
- Ford Hub/Rotor
- FSJ/Chevy stub shaft
- FSJ/Chevy caliper
PIA finding all that?Option 2: my way :gee:
Since it's in Keene... wanna go look at it and see if it's up to snuff? :kissyou:
yeah. for that much it's probably not that good. plus now that I think of it, if it's homemade (probably) it's a pain in the ass to get it on the road in MA for anything over 3,000 lbs. So no worriesButttt, if it happens to be registered for over 3k (6 or 7? :dunno
and not a pile of crap, lemme know
