60" i belive
whats the width on a waggy 44?
60" i belive
im looking into possible options for a dana 44, maybe travis can chime in. i know next to nothing about the 44's. If i were to get a d44 out of a ford f150, can i narrow the long side down to a waggy length shaft. if i do that will i be able to find axle shafts that will fit the f150 spline count? what im getting at is i want a 44 as close to a d30 width with axle shafts readily available . i dont want to be hunting down axle shafts.
travis kept his axle full with, if you want to narrow the f150 axle, you can cut down the pass side to wagy with and use a waggy inner shaft with the f150 outer
and the waggy inners is the same spline count as the f150 inners
pretty much my d30 is trashed. i dont feel like fixing it all. why not upgrade?
60 builds dont cost too much more than 44s and theyre stronger, i see no reason to not build a 60...unless width is real important but that can be overcome pretty cheap too
meh itll handle it haha
i need to get those front stiffeners on, and also the 14bolt is probly gonna require some rear bracing too. damit this buils just keeps getting more expesive
but the end result will be nothing less than awesome
dick
you have 60 rear you cheater
