THe NAC Lots-O-BFG KO2 Thread
that sounds good jon. For the 60 though, you could find like a late 80s ford axle and use a 78/79 passenger side shaft, that would bring the WMS down to around 65" or so I believe. (That's what my front 44 is at)
But, like I said if you're definitely getting no bigger than 37s, the 44 would be fine. Good idea on doing the rear 60 though, definitely...
rear 60's in stock form have 30 spline shafts, same size as a d44 FYI
it wont be in stock form dont you worry about that....i dont like stock
wouldnt that set the diff too far under the oil pan for the UCA? at least thats what ive been reading in a place or 2
run your upper link on the pass side, thats what sean, bill and myself are doing
silly DS UCAs...`
Actually as Colin and I discovered looking at shaft length charts the other night, putting a pass side 78/79 Ford D60 shaft into a mid/late 80s Ford D60 only decreases your overall width by 2.12". This means you'd be at 67.13" (69.25"-2.12") WMS.
boo. gayness. i was just going off the info colin gave me last week :gee:
THAT'S THE LAST TIME I TRUST YOU COLIN!!! :D
nooo. not tearing it apart. swapping a motor. big deal! :dunce:
be a man and swap it out on the trail lol
the thought crossed my mind...
:D
my take on the 44 vs 60 for under a 37" tire size
less unsprung weight. for the win
more clearance. ftw
once the 44 is built up to withstand abuse it costs as much as a 60. for the lose
im glad I did a 44, especially now that i have dropped down to 35's
yep. totally dudeeeee. now, for fear that we get to tech-involved in this thread...
shalamalacka.
my bike rides quite a bit better with the correct tire pressure.
i bet it does!! that's good to hear :)
nope. about 2,000 actually :gee:
...not that any of them held any useful info for anyone :D :D
spare shafts are under pass seat, spare tire is held down by all 3 rear seatbelts and i got a small tool box, the jeep is ready to go, i just need to go and get a few things at the store tomorow
I need to grease the CTMs, throw on a CB antenna, change the fluid in the diffs, and do bumpstops in the front. Then pack up the Jeep and be good to go on Friday. Shouldn't be too much trouble though, oughta do fine. I'll be home from class at like 2pm tomorrow; plenty of time :) unless the bumpstops turn out to be a royal PITA with the ballistic fab coil retainers...we shall see!!
speakin of expensive u joints
colin noticed one of my grease fittings on my super joints snapped off
fml
