THe NAC Lots-O-BFG KO2 Thread
Picked up my new axles today!!!! I was coming back from picking them up and happened to notice a FREE sign on the side of the road. It was 3 stock 8 lug rims with roller tires. BAM!!! i was short one so I grabbed them so I have a complete set now. Turns out they were ford rims and even had the same size tires. Got the axles home and had them unstrapped from the trailer for about 6 minutes before evil thoughts took over. Got the torch and cut the old sway bar, brackets, and track bar setup off.
Version 1 plans
-Narrow long side about 4.5", should put the width to somewhere right around 65"
-Plan is to run stock shafts for now, theres an OEM D60 inner shaft that is the right length, 32ish", but no one seems to make it and they are rarier then hens teeth. I will mostly like have a stock shaft resplined or have a stock alloy made to the OEM specs
-Trim off cast leaf spring mount
-Weld tubes to center section
-Truss the hell outta it
(I'm thinking 3"x3" 0.250" wall rect tube over the center section and 2"x4" 0.250" wall rect tube on the tubes)
-Shave the bottom and plate it with like 1/2"-3/4" plate, grooved to clear the ring gear)
-Ruffstuff cover kit chopped to match the shave
-Run the new Super 60 gears, ratio undecided (bigger then reg 60 gears, but still fit fine)
-A locker, also undecided
-Normal rebuild stuff of all the bearings and seals
-Modify brakes to run 15" steel wheels, I've heard you can do it with the ford twin piston calipers so thats my first option, if not, GM stuff
i think the riddler is gonna need some clearancing to get full steering but i havent really measured anything yet i just mocked that up quickly before i went to georgia
my tubing is 1.5OD .25 wall with .75 heims...i know its way overkill but i had some laying around and i think i can make it work, its getting a TNT truss when i get around to ordering it
DONE! Everything works awesome!
I even got the shifter working. I used 7/16 heim joints with allthread for the linkage. Much easier than the stock linkage. My shift pattern is now backwards but it is much stiffer than stock.
The t-case skid fits too.
All I need to do is either get a new rear driveshaft or have one of mine lengthened.
sweet dude. is the DW gone?
ross, looks awesome
ross, what size tires are you gonna run? my vote is 38.5" SX's
no, still got the dw.
the bracket and brace will be at my house on thursday.
oh yeah...the speedo works too!
no 4wd light though
i want rice krispies treats!
oh yeah...Anthony...4:1 fixes my DW! 12MPH!!!
haha nice dude
adam take some pictures of hte tcase linkage! i'm seriously considering using heims since i had to cut apart my old tcase linkage, and that's basically exactly what i want to do. any more info would be helpful toooo
okay...i'll take some and put them up tonight.
there ya go kyle
ouuu me likey
on second thought. I'm not such a fan of that picture...tranny pan? tranny pan??!!? what kind of gay ass transmission uses those??!? :laugh3:
lol Carmelo is Reptar!
rarrr
