THe NAC Lots-O-BFG KO2 Thread
Re: THe NAC Lots-O-Stove thread
Depends on what everyone else is doing honestly.
At least they are not doing it on a Friday or Saturday night this year. The 7th is Sunday which is better than a weekend evening.
O know the whole DWE crew is gonna be at a wedding. I'm kinda up in the air. Gotta figure out if I'm going to Indy the week before.
dang. what motor and trans mounts are you running?
brown dogs and a crown trans mount thats maybe a year and a half old. Gonna order one of the stinky fab mounts soon and see if thats any better, and i'll update the build thread with pics of the crack later.
About to start swapping in the spare ax15 from old red jeep, hope the rain holds off.
I need to do something about my wheel bearings on the drivers side it keeps loosening up. New hub bearings and nuts didn't help and I am properly torquing it.
On that EB44? Get stage 8s.
What are stage 8s? I'm sick of crying changing only one side. Are they a better locknut? Also scored a 79 ford 9 so I plan to cut it down eb length and go 31 spline chromolly shafts .
Got the trannys swapped, feels awesome except for the unbalanced driveshaft. Swear to ****ing god if that didn't fix this leak and/or I blow something else up in a week and need to drop the crossmember AGAIN im just gonna let it sit till rocktoberfest or something. This months been exhausting.
installer error, or they are damaged.
that nut style was put on 2387425715273485629568343q24255555555346153879142687648923647852314899235752137564213497872165897328279035483726578264780632789457235139257379536544234564152344155344626 different trucks in about a 40 year time span and they never had loosening problems.
Mine loosened up twice. The spindle was just too worn out.
edit: first
X2. I never had any issues with mine. Are you sure you're putting it on correctly and the nuts/lock washers aren't damaged?
edit: first
Sam said it, installer error :shhh:
And you said it yourself, the spindle was too worn. Not an issue with the nut.
The only time I ever found an issue with mine loosening was when the little tit on the washer was worn down too far.
Other than that I've never had an issue.
You gonna attempt Devils Bunghole July ,4th weekend?
Adam had a real bad stomachache on Weds, yesterday afternoon went to the hospital and a few hours later had his appendix removed. He's doing fine and scheduled to be discharged today.
