THe NAC Lots-O-BFG KO2 Thread
Re: THe NAC Lots-O-Post Thread aka North America Home Owners Association Thread
So wanna cut up a car and make it into a go kart, thinking even a yj or tj could be fun
Don't you have a truck you could use?
Hell if you put a go cart motor in it there would be a power increase!
Too soon?
Do it to an XJ.
Dirt cheap and we already know everything about them.
Turbo 4.0 with megasquirt.
Too soon?
Dodge v10 swap, no joke. PS DB Dave is lates
Do it to an XJ.
And a bug bottle of nitrous, just to purge at the starting line.
Re: Re: THe NAC Lots-O-Post Thread aka North America Home Owners Association Thread
2wd Comanche would be perfect. You could cut some camber into the front beam axle and its rigid enough in the back with the "frame". Cut everything out but the firewall.
and I posted that right before you texted me you were here
On my way to what I'm expecting to be another workation. I'd rather be home.
coils I got from dave seem to be the rc 6" with 190lb spring rate, wich is good as I like the rock krawler coils I had with the same rate, gonna pick up same shocks with same valving as bill, should make the frt a lot better. then ill just run dual bilstiens out back
Why double up bilsteins when you can quadruple white bodies?
I want to get a good grease gun. I can't ****ing stand the POS ones in harbor freight and wherever. I don't want air, that's a pain in the ass. Is it worth it to get an electric one?
for personal use, no way. if you work on equipment that has dozens of grease fittings sure.
Snap On or slit your wrists. Your choice.
Everyjuan on the internet says to get a Lincoln pistol grip Juan. Onto the Christmas list it goes
