MoparManiac
- Amherst, NH
The steering trick did jackshit.
I've only ever used an air chisel. Maybe it's the wrong way to do it but all I know is it comes off in 5 seconds and is still good enough to put back on.
http://www.amazon.com/gp/aw/d/B00396DMMA
Lisle sells air chisel bits just for getting those hubs out
I have one of those. It's weird though. Mines's different it looks almost as if someone just cut off the tip of a chisel and welded a lug nut to the end of it :dunno: Weird...
I hit my rotor with a hammer to remove the hub. Worked mint.
Yeah I never had any luck with that either. Made some impressive U-shaped parts though.
You'll probably end up doing a unit bearing on it anyway. Take the hub nut off and beat the shit out of the wheel flange until the unit bearing separates. Once you get the front half of the bearing off, you can remove the ball joint nuts and the shaft has enough play that you can take the knuckle off the inner C and then use a torch/press to get the bearing housing out.
I had to do that twice.
I like how the FSM procedure for taking those out is "partially undo the bolts and tap lightly with a hammer on the bolt heads to dislodge the bearing housing".
:laugh: Awesome.
Do you happen to know what the torque is for the axle nut?
On my truck it's somewhere around 185 lb-ft. Just wondering so I can tell my father since you have the same axle.
What year is it?
Drove the truck to work today. Sold the Subaru 7 hours after I posted it. I had 5 people interested in it. The guy lives in Stoughton (works at Lou's Exhaust) and plans to make it a RSTi me thinks. He's picking it up today.
Who wants to drive with me to pick up some red labels this weekend!?
in Chicopee?
I almost pulled the trigger on those. I figured I should spend my money on the Nova first though
