THe NAC Lots-O-BFG KO2 Thread
rob wins the best picture award. idk what obstacle it is, but it was friday and i have no other rigs in the spot. it was when we went out with scott in the afternoon... lighting is PERFECT.
your'e welcome.
which?
facebook sucks.
facebook pic
flickr pic
yo dizzle guys(Colin, Travis, Bill, Sheep) what treatment do you guys run it the winter for the fuel if any?
Just some sta-bil or cristy dry gas; whatever is on hand.
Edit: Just realized you meant for the trucks, not winter fuel stabilizer for the Jeeps. Duh.
Just the white bottle Power Service stuff and I only run it when it is staying below 20 degrees.
I impulse-bought a food chopper on sale at the grocery store for $7. It's getting into chili season and it seemed like that'd be a good investment. :laugh:
Melamine bonding compound (trade name SeamFil) works exactly as they say it does...fast. Too ****ing fast. No wonder they make a retardant for it. By the time I finished the second joint and went back to clean up the first, it was already cured and was a total pain in the ass to clean the excess off. Will probably end up sanding it tomorrow.
Also decided that before I spend too much time getting the siding back up around my new rear door/half bath reconfiguration, I should probably plan my deck out ahead of time and bolt its main support to the house, so I don't have to redo all the siding again once spring comes around and I can start building the deck. Pretty silly to do all the siding trim work around a door that's still floating in space on the side of the house but I don't want to spend the winter with everything exposed either.
Also found out that the "wood" stove is actually a coal stove, handmade by some dude in the Pine Barrens, and that kicks ass. Looks like I'm heating with coal this winter. Should cost me about $250 for the equivalent BTU's of 200+ gallons of heating oil, and run for 12+ hours at a time...basically dump a bucket in the morning before I leave for work, dump one later that night when I get home, and shake the ashes & clinkers out before that second fill.
/housepeopleproblems
Nothing really. I go through diesel too fast. I used to religiously use Power Service in my truck. Put some in every other tank. Then I got fed up with buying it and didn't use it. Haven't noticed any difference.
I didn't even put anything in my MJ last winter. Granted I would run it up to temp every now and then since I was tuning.
My father's truck needs front axle u-joints.
Thank god Spicer makes some.
Apparently they use 5006813 which is a 1485WJ? Weird.
If you haven't ordered yet, LMK, we can usually get most any Spicer in 2 business days as cheap as you'll find it with no shipping. :D
Don't bother, winter blend #2 has some extra gelling stuff and its just fine. My truck runs just fine and I don't go thru tanks nearly as quick as say Colin, usually two or three weeks
I always add 8oz of two stroke tcw3 oil to every tank, year round because lb7 injectors are assholes. In the winter I use the white bottle power service stuff every other tank. Haven't noticed a difference either way like Colin said but I figure it can't hurt.
The one time I risked it is the one time I had gelled fuel.
It's like an extra $0.053/gallon which hurts but not as much as loosing almost all power pulling out in the middle of intersection because of gelled fuel.
I don't notice a difference either.
Last winter was my first and didn't do anything and it didn't have any problems. Though I did do a lit of research on the matter everyone said for lly not to and I only plugged it in when it dropped below 10 outside power the manual
