THe NAC Lots-O-BFG KO2 Thread
Colin travis 630ish tonight? Colin I still got them 1350 ubolts if you want em
Anyone know what size/thread the steering shaft bolt is?
I think it's M8 x something.
Mine's a bit mangled.
the one that secures it to the box? pretty sure its M10x1.5, maybe 30mm length?
I may have found some 33s reasonable,
70-60 percent tread Km2s on 16x8 worth $600?
For crying out loud, just run boggers.
6:30 should work for me.
Yup the one that secures it to the box (orbital in my case). I thought M10s usually had a 15mm head? This one has a 13mm head which an M8 usually has...
You coming tonight?
5 tires
They are load range E though
That's not bad. They won't flex or grip as well off road as a load range c which you might not enjoy. But they are on a tougher carcass.
J420 0400, M8x1.25 30mm. Make sure you get one with the right unthreaded shank length if possible, though it doesn't matter as much with hydro steering probably.
Mcmaster will give me a pack of 25.
If I chew threw one every 2-3 years I'll be good for a while.
:laugh:
That's what I figured :laugh2: and with the hydro steering isn't there basically no effort in turning the wheel? I doubt you'll wear out even one.
Im thinking its a go for me then, I dont see it as to bad, and its better than my current at's.
Do I need to ask for anyone special at Crown if I'm looking to pick up parts today?
Ask for Carmelo. If you get Jeff demand to get transferred to Carmelo. Jeff is kinda an idiot and might laugh at you.
Signed up for offcamber
Refereed by hellride :wave:
maybw ill see you there ;) I gotta swing by and grab my ball joints. what time you going?
