THe NAC Lots-O-BFG KO2 Thread
is it too much to ask a company to make parts that actually fit? my pinion skid and diff cover holes are all off. yes i installed every bolt loosely. i even ordered longer bolts from them and they are the wrong diameter. looks like im drilling holes bigger and making a run to the hardware store. lesson learned. dont order from a company that has the same products as ruffstuff for a few bucks cheaper.
Lesson learned rustys mj leafs are nice but the bushings blow chunks and stock ones don't fit. Temptation to buy a big chunk of 2.5" polyurethane and turn myself some bushings: rising
Seems the leafs have a 2" ID main eye and a 1.5" ID shackle eye. Stock is 2.5" and 1.75" :bs: why would they even do that?
I'd expect Travis to just get fed up with it and wheel it the way it is until it breaks in half, not scrap the whole thing
Screw it. Here's my hunk of shit now.
don't say that, I have a lot to hack together on the MJ before it is ready for NACFest.
I did just fix my high lift for $1 though. Had to replace the cross pins through the ratchet pins and High Lift wants $28 for the kit, so I bought a piece of 3/16 steel rod and cut pieces to fit.
that was dumb if its the piece i'm thinking it might be...1/4" ratchet extention fits mint, and it doubles as a 1/4" ratchet extention!!!
I forsse travis and mine biggest obstacle as memorial weekend as I belive both f us will be a little brave with our new cages
yup. hopefully i'll be done by then. i'm going to spend a lot of time working on it, weather permitting, but i'm not going to rush it. tube is too expensive to hack this together heh
not the little peg that holds the base onto the vertical piece, the little pegs that go through the ratcheting things and ride on the cam thing that sets whether it's going up or down.
I already have the old door latch actuator rod from some random junkyard vehicle holding the base onto the vertical piece on mine :gee:
gotcha. fair enough :thumbup:
Fact; that's my 1/4" extention in your high lift from when I blew up my 30 outer a long time ago.
yea. keiths new tires are pretty gay. nothing cool going on there or anything.
Was just gonna say I can't believe no one said anything. Thing looks BALLIN. did a lot of cage work today, build thread update tomorrow night.
And Sam, that sucks. If ruffstuff sells something, I don't buy it from anywhere else.
someone tell me what fuel cell and pump i want
i need 12-14 psi of pressure and want it to run sideways
Get somthin like colins setup ill never do an and npt fittings again takes forever to fix all the leaks then shit still leaks
